Home :: GUIDE - TCCX# Torque Converter Fitment
You can find the smaller TCC12## install guide by clicking here
Looking for the measurement between the crankshaft on the engine, and the jackshaft holding the driven pulley?  The distance between the two centres of the TCCX high power torque converter should be 207mm
Craig Chaffey's installation looks super-tidy, using just the components inside the CPR TCCX kit:
When fitting our TCCX1C kit, here is a solution one of our clients came up with, using everything in the kit plus some additional spacer tube to space out the driven pulley from the jackshaft sprocket:
