Home :: Steering Components :: Stub Axles & Spindles :: Stub Axle PROJECT SERIES Spindle Suit Arrow CRG Silver Pair w/Black Spacers and Brackets AND CAMBER ADJUSTERS
The PROJECT SERIES range of CPR products includes Brackets which weld to your frame to accept these spindles.  Your complete kit comes with two spindle brackets which can be welded to your project or existing kart frame to update/upgrade to CPR spindles.
Colour: Silver
INCLUDES
- KING PIN BOLTS
INCLUDES SPACER WASHERS (One set of 8 - 4x10mm & 4x5mm spacer washers - Colour as per title & title picture - NOTE: You may require additional spacers depending on the distance between the outer faces of your rims or hubs)
- WHEEL NUTS
- BEARINGS
- BRACKETS (Compatible with our CMBC01 camber adjustmernt kit included with this bundle)
- 14mm-8mm CAMBER/CASTOR Adjusters
KING PIN Diameter: 8mm
Dimension A: 100mm
Dimension B: 18mm
Dimension A+B: 118mm
Dimension C: 22mm
Dimension E: 52mm
Dimension F: 2mm
Dimension C+D+E+F: 172mm
StubAxleGuide
SKU STACPK
Regular price: $1067.56
