Home :: Sprockets & Chains :: 219 Pitch Sprockets :: Sprocket Front (KT100 Short Shaft Red Clutch) 219 Pitch 10 Teeth Extended KIT
Alloy 219 Pitch Engine Sprocket.
Suits KT100 Red Clutch (Short Shaft)
These fit all short shaft KT100 Red Clutch drums.  This is a complete kit to bring the sprocket outboard.
219 Pitch
Number of teeth as per title.
All parts in the pictures included.
Sprocket
Sprocket Bearing
Sprocket Bearing Bush
Extended Shaft
Extended Shaft Bearing
Fixing Nut
Learn how to install the extended kit by clicking the "Learn how to install a KT100 Clutch" picture below.
KT100ShaftGuide
SKU SPFRE10K
Regular price: $188.82
Price with FREE DELIVERY: $119.90
Bearing (Clutch Outer) for Red Clutch suits Short Shaft 9T Extended Sprocket
Extension Shaft for Red Clutch suits Short Shaft 9T Extended Sprockets
Bearing (Clutch Outer) for Red Clutch suits Short Shaft 9T Extended Sprocket Extension Shaft for Red Clutch suits Short Shaft 9T Extended Sprockets
$16.95
$49.95
Fixing Nut for Red Clutch suits Short Shaft 9T Extended Sprockets
Sprocket Front (KT100 Short Shaft Red Clutch) 219 Pitch 9T 9 Teeth Extended SPROCKET ONLY
Fixing Nut for Red Clutch suits Short Shaft 9T Extended Sprockets Sprocket Front (KT100 Short Shaft Red Clutch) 219 Pitch 9T 9 Teeth Extended SPROCKET ONLY
$14.95
$84.95
