Home :: Engines, Carbs & Parts :: Key for GX160/GX200/GX270/GX390 Flywheel - Offset 6 degree advance GX200 (8 degree GX390)
Key - suits GX200 and GX160 - Advances ignition timing by 6 degrees on a GX200
or by 8 degrees on a GX390
Recommended for use in GX200s on Pump Fuel and 160s on with stock flywheels
Installation:
Remove Flywheel.  Looking at flywheel side of the motor, install timing key with the notched part to the left.  Install flywheel and rotate as much as possible clockwise.  After flywheel in installed, use torch and look into keyslot, making sure flywheel is rotated/installed as shown.  Install and tighten flywheel nut.
SKU EFWOK6
Flywheel Budget Racer - Genuine Honda Alloy suit Honda Clone GX200 & ENCL65
$159.00
