Are you searching for all the gaskets required to rebuild the ENCL65 or ENCLST1 CPR 196cc or a Honda Clone GX200 engine?
It's a question we get asked all the time - which gaskets do I need to rebuild my engine? So that you don't buy too many, or too few gaskets and seals we've compiled this simple to follow list to ensure you get all the parts you need before you start pulling your engine down.
CRANK CASE
For the bottom end, you will need the gasket for the side cover. If it is one of our CPR (Lifan) engines and has 4 bolts on the rocker cover you need this one:
| Crank Case Gasket CPR Performance Suit 4-Bolt Head Type Honda Clone ENCLST1 |
SKU: GCCB02
And if it has 5 bolts on the rocker cover:
| Crank Case Gasket CPR Performance Suit 5-Bolt Head Type Honda Clone ENCL65 |
SKU: GCCB01
| Head Gasket Stock Clone Suit Honda Clone GX200 ENCL65 |
SKU: GHLC01
Or Increased compression viton coated steel 0.10mm thin gasket (this is a great way to increase compression slightly on a completely stock engine, providing a small but valuable power improvement). These can also be used on modified engines assuming the engine has been not been specifically built to run a stock gasket.
Head Gasket CPR Performance Increased Compression Suit Honda Clone GX200 ENCL65
| Rocker Tappet Valve Cover Gasket CPR Performance Suit 5 Bolt Honda Clone GX200 ENCL65 |
SKU: GRCB51
| Gasket Set Air Inlet Manifold, Vacuum Sandwich, Carb & Venturi suits GX200 6.5hp and Clone engines |
| SKU: GSAIC1 |
