Home :: Tools, Starters & Chargers :: Tools :: Fuel Pump Decanter Transfer Battery Powered Jerry Can to Tank
Don't spill a drop of precious fuel with this amazing fuel decanter.
Designed for easy and fast decanting of fuel from a jerry can directly into your tank!
Uses 2x D-Cell batteries.
AVOIDS DANGEROUS AND COSTLY SPILLAGE
Our new pump solves the hazardous challenge of pouring a jerry can into your fuel tank.  If you're looking for a better way then this is it!
EASY TO USE
Just submerge the handle into your jerry can and route the flexible hose into your kart fuel tank.  Flick the on switch and watch it do the work for you!
PROVEN QUALITY
Durable nylon construciton ensures you have a working pump every time.  Used in the industry by hundreds of karters - they wouldn't be buying it if it wasn't quality!
LONG LASTING BATTERY TYPE
Easy to source D size batteries are used to ensure long life so it's charged wihen you need it most.
Length of pickup tube from centre of taper below output tube is approximately 360mm (reach into jerrycan)
SKU FPDESS
