Home :: Axles & Parts :: 40mm :: Complete 40mm Axle Kit 8mm Keyway Silver (85mm Long Rear Wheel Hubs)
 ***THIS MODEL SUPPLIED WITH 85mm LONG REAR WHEEL HUBS***
COMPLETE 40mm AXLE ASSEMBLY.  EVERYTHING you need to bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!  This is a dream price!
Total Value - $676 (see prices below)
1x 40mm Axle Shaft ($120)
1x Drilled Brake Disc ($120)
Axle Length: 1050mm
Keyway locations:  from end to end:
@ 10mm->75mm
@ 120mm -> 185mm
@ 350mm->400mm
@ 740mm->790mm
@ 975mm -> 1040mm
Length: 85mm
SKU AXCC408S_85
Regular price: $1989.89
$29.90
