Home :: Clutches :: Weight Set for RPM Engagement Lowering suits NORAM Cheetah
Complete weight set to suit NORAM Cheetah
This part allows you to lower the RPM Engagement speed from 4000rpm down to 3500, 2800, 2100 or 1850rpm.  This will give you a massive advantage allowing you to tailor your engagement speed to suit the torque curve of your engine.
View or download the user manual / maintenance guide here: http://cutpriceracing.com.au/phpbb3/viewtopic.php?f=14&t=256
View or download the Engagement speed adjustment manual / guide here: http://cutpriceracing.com.au/phpbb3/viewtopic.php?f=14&t=257
View or download the spring replacement guide here: http://cutpriceracing.com.au/phpbb3/viewtopic.php?f=14&t=255
SKU CSWCH1
