.jpg)
BREAKING THE CHAIN.
When breaking or re-joining chain, always use a hand tool like a hex key bar.  Never use a power tool or an impact wrench.
.jpg)
IMPORTANT!  Attempting to remove a pin from a chain without proper care and attention risks damaging the chain breaker tool and/or the chain.
    .jpg)
    Place your      chain in the breaker, with the chain pin you want to remove in-line with the Pin Screw.  *TIP: Spray some lubricant/chain lube on the chain pin you're going to remove to make the process easier and avoid damaging the inside of the roller.
    .jpg)
    Wind the Pin Screw in until it      just touches the chain pin.
    .jpg)
    Giggle the chain a little so      that the chain pin is as close to centred with the bolt pin as possible.
    - Begin to slowly turn the Pin Screw in to push the pin out of the chain.
        - You will       feel some resistance.  There should       not be a large amount of force needed to move the chain pin.
        WARNING - USING FORCE TO PUSH THE PIN OUT CAN BREAK THE PIN SCREW!  USE CAUTION AND FOLLOW THE STEPS BELOW.
        - If the force required seems       high, or you're not sure, back the Pin Screw out slightly to allow the chain       to move, then giggle the chain.        Then try again.
        - Sometimes you may need to       hold the breaker on an angle or upside down so the chain rests in a       slightly different position.
        - Eye-ball the chain pin and Pin Screw pin to make sure they are aligned.
        - Keep backing out and then       pushing the chain pin until the chain pin moves slightly.  Then back the bolt back out a little.
        - At this point the chain pin will       move but you may not be completely centred.
        - Line up the chain pin on the pin in the Pin Screw and screw it back in again, keeping it aligned.  If at any point you're not sure if it's       aligned, back it out, giggle, and go again.
        - The chain pin should now push out       with little force required.  If       there is still reasonable force required, the pin on the Pin Screw is not properly       centred.  Back it out and try       again.
    .jpg)
    Push the chain pin through until      the chain pin is just in the last outer plate on the other side (not completely      out).
        - You'll       know when you've gone far enough by backing out the Pin Screw and then       lifting the chain to see if it disconnects from the link with the chain pin.  If it requires a lot of force       to disconnect, then you haven't pushed the chain pin out enough.
        .jpg)
        - On our 219P chain breakers,       there is a slot designed to retain the chain pin.  (see picture).  With those models, you can keep pushing       the chain pin until you feel resistance.        The slot should be the exact amount of width required to push the chain pin as far as needed but not out of the chain plate entirely.
        .jpg)
RE-CONNECTING THE CHAIN
    - Remove or      back out the Pin Screw so that it does not protrude into the chain rail area of the tool (centre part)
    .jpg)
    Back the Screw (non-pin screw) out      until the slot on the Screw side of the tool is clear.
    - Insert the side of the chain      with the chain pin hanging out the side of the plate into the tool, with the chain pin      located in the slot in front of the Screw.
    .jpg)
    Insert the roller end of the      chain (the other part to be joined) into the chain in the tool so the assembly is sitting into the rail.  Try to align the chain pin with the chain roller as      well as you can.
        - You can       usually visually tell by eye-balling the height of the plates on both       ends of the chain.  If one end       looks like it's sitting higher then it is not aligned.
    - Wind the Screw in slightly      until it just touches the chain pin.
    - Eye-ball the chain pin and make      sure it is centred on the Screw end.  The      Screw end is concave so it should help centralise the chain pin but it is not enough      to simply rely on this alone.  If it      is not centred, back the Screw off and adjust as necessary.  Sometimes you may need to remove the      chain and manually adjust the chain pin by hand.
    .jpg)
    Slowly wind the Screw in to      push the chain pin into the chain.
        - IT IS VERY       IMPORTANT not to force the chain pin into the chain.  It will damage the chain roller and create a       tight spot.  You will need to       replace a link if it is tight as it will cause issues when in use.
        - If the pin seems to require       a lot of force to push in then there is a problem.  The plates and roller and pin are not       aligning.  Sometimes it helps to       giggle the chain while it is still in the tool, by backing off the Screw a       touch to relieve pressure on the chain pin.
        - SLOW AND STEADY IS THE KEY.
    - The resistance will drop away      suddenly once the chain pin is inside the roller.  Keep winding until you feel the next      resistance.
    - You will feel resistance when      the chain pin exists the chain roller on the other side and enters the plates on the      outside of the chain on the opposite side.       This resistance should be similar to the initial resistance at the      beginning of reconnecting the chain.
    - If the resistance is      significant, stop the process, back the Screw off a touch, and then      re-align the chain by wiggling in the tool.  Check to make sure the plates are lined      up.  Sometimes it does require      removal of the chain at this point and some giggling and rotating of the      link to allow the plate to adjust correctly.
    - Sometimes, with slightly      lighter manufactured chains, the plates may be a touch thinner which can      allow the plates on the outer side to flex.
        - If the       outer plates start to bend, then check alignment.
        - If the outer plates start to       bend and you're certain the alignment is good, you can shim the space       between the outer plates and the tool with a fine washer.  Make sure you do not impede the ability       of the chain pin to protrude through the outer plate when done.
    .jpg)
    Push the chain pin further by tightening the Screw until the Screw end just touches the chain plate.
    - If the chain pin is not perfectly positioned with the same amount protruding out of the plate as other links after this, you can remove the chain and insert it into the Pin Screw position of the chain rail and use the Pin Screw to make a small adjustment by pushing the chain pin in a tiny amount.
    .jpg)
    .jpg)
    .jpg)
