Home :: GUIDE - GX200 & Clone List of Gaskets with Store Links
List of Gaskets for full GX200 & Clone Rebuild:
Head Gasket:
Valve Cover (Rocker Cover) Gasket:
Crank Case (Side Cover) Gasket:
https://cutpriceracing.com.au/store/Crank-Case-Gasket-CPR-Performance-Suit-4-Bolt-Head-Type-Honda-Clone-ENCLST1/ (note: these are not definitively compatible with all lGX200/Clones – some have a different crankcase design – you’ll notice they won’t ‘quite’ fit those. However, this is the most common. If in doubt, silicone or cutting your own out of gasket paper will work)
Exhaust (Muffler) Gasket:
Inlet Gasket Set (Carb/head/inusulator/Venturi Adaptor Gaskets):
Oil Seals:
Valve Stem Seals:
Crank Oil Seal:
