Home :: Bearings :: Wheel Bearing 17mm ID 35mm OD 4pk TIMKEN Race Spec (NON-CONTACT Low Resistance)
BRAND NEW 4pack (to do 2 front wheels) bearing. Brand New! Don't buy more than you need ! Get just the 4!
These are the highest quality American brand low friction rubber sealed TIMKEN bearings available.  If you're looking for the absolute best front wheel bearings, these are the ones you need.
These premium race grade TIMKEN bearings are a non-contact rubber seal style bearing which provide maximum speed and minimum friction.  These are the best bearings on the market right now for racing kart front wheels by a mile compared to our SKF model which have contact-rubber-seals that introduce friction.
17mm Inner diameter (stub axle diameter)
35mm Outer Diameter (Front wheel hub inner diameter)
SKU BWSQBT
