Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Genuine Walbro Carburettor Carb Carby WB3A suit KT100J KT100S
Genuine Walbro Carburettor Carb Carby WB3A used on KT100S & KT100J engines.
Looking for base fuel jet settings?  CLICK HERE to view our guide.
IS YOUR KT100 FEELING DOWN ON POWER?
You might think you've got a compression problem, but it's more likely you have a carburettor issue, robbing precious power from your Yamaha engine.
GET BACK YOUR LOST POWER
As your KT100 engine is used, every time you open and close the throttle you wear the body of your carb at the throttle shaft. There is no way to repair that damage, so you’ll leak more and more air, creating a performance loss. Replacing your carb will get back your lost performance.
KT100S AND KT100J
Ready to fit to your KT100S or KT100J engine - plus we carry a full range of gaskets and rebuild kits, including hard to find parts like phenolic spacers so you can keep your KT100 at the front of your field.
READY TO FIT
Set up out of the box ready to bolt on and go - our genuine walbro carbs do not need adjustment when fitted to a KT100S - just fit it and experience a new level of performance from your engine! Easy!
SAME DAY DISPATCH
If you want to get your hands on one today we’ve got them in stock and ready to ship! So you don’t need to waste any time - get ready to drive! Faster!
SKU CWB3A1
