Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Walbro K10-WB Overhaul Kit & Pop-Off Spring suit Yamaha KT100J/S WB3A Carb
Suit Walbro WB Series Carbies (such as WB-3A commonly used on KT100J & KT100S engines).
THIS MODEL INCLUDES THE POP-OFF SPRING.
I BET YOU WON'T FIND A CHEAPER ORIGINAL WALBRO OVERHAUL KIT IN AUSTRALIA!
Please note: This is the ORIGINAL WALBRO Part - NOT A CHEAP IMITATION.
Does your carbie seal properly? Do you hold pressure on pop-off? If you don't, or you're not suer, you need to replace your needle. Cheap and effective way to maximise horsepower and correct starting problems.
Walbro Brand Overhaul Kit - includes SPRING, Needle/Seal/Lever/Gasket set. Suit WB series Carbys such as WB-3A used on KT100S & KT100J engines.
NEW.
SKU K10WB_S
Regular price: $32.64
Price with FREE DELIVERY: $29.95
