Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Venturi Adaptor Adapter (Tillotson) for Air Filter FLC01 suits Tillotson 334 Carb & GX200
Venturi adaptor for Air Filter.  Comes with boltsi allows the Air Filter FLC01 to bolt to our LIFAN 6.5hp engines.
Suits Tillotson Carburettors including LIFAN 6.5HP honda clone engines (where Tilltson Carbs are fitted)
If you are looking to adapt this item to another filter or carburettor, stud spacing is ~49.5mm centre to centre, 4mm retaining bolts.  Centre of venturi has a hole 30mm diameter.   Outer diameter is ~63mm.
SKU FLVA01
$26.95
