Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Venturi Adaptor Adapter for Air Filter FLC01 suits 4-Stroke Engine GX270 up to GX390 and Torini Clubmaxx
Venturi adaptor for Air Filter.  Venturi allows the Air Filter FLC01 to bolt to GX270 - GX390 engines and Torini Clubmaxx
If you are looking to adapt this item to another filter or engine, stud spacing is 52mm centre to centre, 6mm studs.  Centre of venturi has a hole 30mm diameter.   Outer diameter is 62mm.
SKU FLVC39
