Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Venturi Adaptor Adapter (Tillotson) for Air Filter FLC01 suits Tillotson 304 Carb and GX200
Venturi adaptor for Air Filter.  Comes with boltsi allows the Air Filter FLC01 to bolt to our LIFAN 6.5hp engines.
Suits Tillotson 304 Carburettors
If you are looking to adapt this item to another filter or carburettor, stud spacing is ~49.5mm centre to centre, 4mm retaining bolts.  Centre of venturi has a hole 33mm diameter.   Outer diameter is ~63mm.
SKU FLV304
$26.95
