Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Venturi Adaptor Adapter RED with Choke Bracket for Air Filter FLC01 suits Upgrade Kit for 4-Stroke Engine LIFAN OHV 6.5hp 192cc
ANODISED RED Venturi adaptor for Air Filter.  Comes with Gasket and Venturi allows the Air Filter FLC01 to bolt to our LIFAN 6.5hp engines.
Suits upgraded LIFAN 6.5HP honda clone engines (using our Upgrade Pack - ENUCL65).
Includes choke bracket and rubber spacer gasket and screw (not pictured)
If you are looking to adapt this item to another filter or engine, stud spacing is 43mm centre to centre, 6mm studs.  Centre of venturi has a hole 25.5mm diameter.   Outer diameter is 62mm.
SKU FLVC1R
Price with FREE DELIVERY: $59.95
