Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Venturi Adaptor Adapter (Mikuni 22mm Style) for Air Filter FLC01
Venturi adaptor for Air Filter.  Comes with set screw allows the Air Filter FLC01 to bolt to our Mikuni 22mm Slide Carb.
Suits 22mm Mikuni Slide Carb (see related items below)
If you are looking to adapt this item to another filter or carburettor, this item has a section that slides over the venturi/neck of the slide carb which is approximately 39.5mm and uses an included set-screw to hold onto the carb neck.   Outer diameter is ~63mm.
SKU FLVMN2
Mikuni Slide Carburettor Carb Carby 22mm suits Honda GX200 & Clone
Air Filter suits Upgrade Kit for 4-Stroke Engine Mikuni Slide Carburettor Carb Carby 22mm suits Honda GX200 & Clone
$26.95
$89.90
