Home :: Engines, Carbs & Parts :: Engines :: Valve Stainless Steel & Spring Kit with Retainers Lash Caps Chromoly Pushrods and Gaskets Suit Honda Clone GX200 ENCL65
1x Pair 26lb Springs
Have you changed your cam? If so, you need these springs.
When you're increasing your LIFAN 6.5hp engine or Honda GX160/200 clone rev limit by removal of the standard governor and addition of higher lift cams these precision made CPR Perfromance 26lb valve springs are the ideal solution.
Can also be fitted to Torini Clubmaxx and other Predator 212cc engines. For newer style predator engines (like Torini Clubmaxx) this spring will have a slightly higher pressure.
Eliminates normal valve float and prevents valve breakage. Includes heavier springs 26 lb Springs
1x Exhaust Valve - Stock size (24mm Dia) STAINLESS STEEL -uses aftermarket collets - polished valve.
65.5mm long (1.78mm longer than standard)
1x  Inlet Valve - stock size (25mm Dia) STAINLESS STEEL uses aftermarket collets - polished valve.
67.05mm long (3.33mm longer than standard)
2x Sets of Valve Collet & Keeper (Retainer) - Suits CPR Stainless Valves.
Suits up to 26lb CPR Perfromance valve springs
2x Lash Caps
2x CPR Performance Chrome Moly push rods are the most affordable strong and light push rods available on the market for 160/200 Honda GX, and Clone engines.
These rods are fixed length standard length GX200 pushrods. (5.260inch - 133.60mm long, 4.85mm thick)
2x CPR Performance guide plate Replaces stock guide plate to accomodate the thicker pushrods included in this kit.
1x Rocker Cover (Tappet Cover) Honda Clone Gasket.
1x Increased compression CPR Performance Honda GX200 & Clone Head Gasket.
BSP/Clone High Performance Head Gasket
This is a Steel, Viton Coated, .010 Head Gasket.
Viton is an extremely durable, heat resistant coating that is used to insure better sealing than a untreated, stock gasket.
HeadTearDownGuide
SKU EKMMCV
Regular price: $334.91
Price with FREE DELIVERY: $284.90
