Home :: Engines, Carbs & Parts :: Engines :: Valve Spring Kit with Retainers Lash Caps Chromoly Pushrods and Gaskets Suit Honda Clone GX200
RPM HOP UP KIT, Comprises of the following
1x Pair 26lb Springs
Have you changed your cam? If so, you need these springs.
When you're increasing your LIFAN 6.5hp engine or Honda GX160/200 clone rev limit by removal of the standard governor and addition of higher lift cams these precision made CPR Perfromance 26lb valve springs are the ideal solution.
Can also be fitted to Torini Clubmaxx and other Predator 212cc engines. For newer style predator engines (like Torini Clubmaxx) this spring will have a slightly higher pressure.
Eliminates normal valve float and prevents valve breakage. Includes heavier springs 26 lb Springs
1x Retainer and lash cap kit
Install these on the valve that has no lash cap to provide a more reliable retainer design for higher rpm.  This is the system we use on our race motors which is super reliable with 26lb valve springs.
2x CPR Performance Chrome Moly push rods are the most affordable strong and light push rods available on the market for 160/200 Honda GX, and Clone engines.
These rods are cut-to-length (standard length GX200 pushrods are 5.260inch - 133.60mm long,) 4.85mm thick.
2x CPR Performance guide plate Replaces stock guide plate to accomodate the thicker pushrods included in this kit.
1x Rocker Cover (Tappet Cover) Honda Clone Gasket.
1x Increased compression CPR Performance Honda GX200 & Clone Head Gasket.
BSP/Clone High Performance Head Gasket
This is a Steel, Viton Coated, .010 Head Gasket.
Viton is an extremely durable, heat resistant coating that is used to insure better sealing than a untreated, stock gasket.
HeadTearDownGuide
SKU EKMMCV_WOV
Regular price: $180.55
Price with FREE DELIVERY: $149.00
