Home :: Engines, Carbs & Parts :: Engines :: Valve Spring 36lb CPR Performance Set Kit - suit ENCL65 and Honda GX160/200 clones
Have you changed your cam?  If so, you need these springs.
When you're increasing your LIFAN 6.5hp engine or Honda GX160/200 clone rev limit by removal of the standard governor and addition of higher lift cams these precision made CPR Perfromance 36lb valve springs are the ideal solution.
Pair of valves (2pcs)
Eliminates normal valve float and prevents valve breakage. Includes heavier springs  36 lb Springs
HeadTearDownGuide
SKU EVSBRK36
