Home :: Engines, Carbs & Parts :: Engines :: Valve Spring 26lb COMPLETE KIT with Retainer & Lash Cap CPR Performance Set Kit - suit ENCL65 and Honda GX160/200 clones (and Torini Clubmaxx / Predator 212cc)
This is a complete kit which includes a new retainer to suit the included lash cap so you can run a lash cap on both valves on a standard GX head.
Have you changed your cam?  If so, you need these springs.
When you're increasing your LIFAN 6.5hp engine or Honda GX160/200 clone rev limit by removal of the standard governor and addition of higher lift cams these precision made CPR Perfromance 26lb valve springs are the ideal solution.
Can also be fitted to Torini Clubmaxx and other Predator 212cc engines.  For newer style predator engines (like Torini Clubmaxx) this spring will have a slightly higher pressure.
Eliminates normal valve float and prevents valve breakage. Includes heavier springs   26 lb Springs
HeadTearDownGuide
SKU EVSBRK26K
Regular price: $49.86
Price with FREE DELIVERY: $47.95
