Home :: Engines, Carbs & Parts :: Engines :: Valve Spring 22lb CPR Performance Pair - suit ENCL65 and Honda GX160/200 clones (and Torini Clubmaxx / Predator 212cc)
Have you changed your cam?  If so, you need these springs.
When you're increasing your LIFAN 6.5hp engine or Honda GX160/200 clone rev limit by removal of the standard governor and addition of higher lift cams these precision made CPR Perfromance 22lb valve springs are the ideal solution.
Can also be fitted to Torini Clubmaxx and other Predator 212cc engines.  (We have noticed that the new batches of Torini Clubmaxx have a stiffer spring than the 22lb).
Complete kit.
Eliminates normal valve float and prevents valve breakage. Includes heavier springs   22 lb Springs
29.5mm uninstalled height.
FITS:  Predator 212 Engines as well as All CPR Lifan 6.5hp engines.  All Honda GX160 & GX200 engines & Clone GX160 & GX200 engines.
HeadTearDownGuide
SKU EVSBRK22
