Home :: Engines, Carbs & Parts :: Engines :: Valve Roller Rocker Arms Pair CPR-GT Performance 1:1.0 Ratio - suit ENCL65 and Honda GX160/200 clones (Original Type)
ORIGINAL TYPE
**THIS MODEL DOES NOT NEED THE VALVE COVER TO BE CLEARANCED LIKE THE NEWER MODEL DOES**
CPR GTperformance low-drag Roller Rockers to suit Honda GX200/160 and clone engines including all CPR GX200 engines as well as Predator.
Forged Steel construction to provide ultimate reliable power for your modified race engine.
High strength and durability.
These rockers are an absolute steal!  You simply can't beat this performance for the $.
This style of rocker eliminates the need for a guideplate and prevents the rocker arms from walking side-side. Furthermore, they have considerably more ridgidity than stud rockers so they rarely need adjustment once set.
1:1.0 Ratio
Studs and Nuts included.
Will not fit hemi-style cylinder heads on some predator 212cc engines (70mm bore)
Simple to install. Works with stock length Chrome Moly Push Rods.
HeadTearDownGuide
SKU EVRRV1
Pushrod Guide Plate CPR Performance Billet suit ENCL65 and Honda GX160/200 clones
$19.95
