Home :: Engines, Carbs & Parts :: Engines :: Valve Rocker Arms Pair CPR Performance 1:1.1 Ratio - suit ENCL65 and Honda GX160/200 clones (Re-Inforced)
Complete kit of 2pcs.
CPR Performance Rocker Arms, 1.1 Ratio. SET OF TWO PIECES
REINFORCED
We recommend using our Billet Guide Plate with this item to ensure the increased angle of the pushrods do not foul the stock guide plate. When using with EGPA01 Billet Guide Plate you may require EHSAM1 as some engines will not allow for the room needed for proper operation of the 1.1:1 increased angle and may result in bent or damaged rockers;
HeadTearDownGuide
1-1-3-RockersGuide
SKU ERKB02
