Home :: Engines, Carbs & Parts :: Engines :: Valve Rocker Arms Billet Pair High Performance 1:1.2 Ratio - suit Predator 212 Hemi and Torini Clubmaxx
Complete kit of 2pcs.
High Strength BILLET Steel CPR High Performance Rocker Arms, 1.2 Ratio. SET OF TWO PIECES
We recommend using our Guide Plate with this item.
FITS:  Predator 212cc Hemi-Head (identifiable as the model with the cast rocker cover) and Torini Clubmaxx
· Hardened roller tips and shafts
· Dyno tested to 10,000 rpm and proven to make more horsepower
· Uses stock pin & Clips
May require valve cover spacer or minor grinding on valve cover grinder for clearance (for Torini Clubmaxx the easiest solution is a valve cover spacer)
Due to canted valve arrangement, Hemi's may have valve to piston clearance issue with high lift cam, esp with 1.2 Ratio
These Rocker Arms require shorter Pushrods, typically 5.260 or 5.340 depending on cam and head milling. 1.2 ratio or 1.2 Ratio
Note: These are designed to work with standard length or +.070" valves, they are not recommended for the +.230" valves.
HeadTearDownGuide
SKU EVRNBP2
Pushrod Guide Plate CPR Performance Billet suit ENCL65 and Honda GX160/200 clones
$19.95
