Home :: Engines, Carbs & Parts :: Engines :: Valve Pair EXHAUST 24mm and INLET 25mm SHOP SOILED Stainless Steel Polished Suit Honda Clone GX200 ENCL65
SHOP SOILED
Exact item pictured - ONE SET ONLY - grab this bargain now before it's snapped up by someone quicker.
This pair of valves was installed in an engine, run on the stand for a short period to test, and then removed from the engine.  This was a test prototype.  These are the same valves as our brand new Stainless Steel valves which retail at $45ea.  There is no damage - just carbon deposits.
Exhaust Valve - Stock size (24mm Dia) STAINLESS STEEL -uses aftermarket collets - polished valve.
65.5mm long (1.78mm longer than standard)
Inlet Valve - stock size (25mm Dia) STAINLESS STEEL uses aftermarket collets - polished valve.
HeadTearDownGuide
SKU EVG2SS
Price with FREE DELIVERY: $59.95
