Home :: Engines, Carbs & Parts :: Engines :: Valve Cover Rocker Tappet Studs Stud set kit (4 Pack) CPR Race premium strength GX200 GX160
Increased strength head studs (CPR Performance).  Designed for extreme racing engines.
Pack of 4pcs - full set
If you're sick of having to tighten loosening valve cover bolts then this kit will solve your headaches!
FITS:  All CPR 6.5hp engines.  All Honda GX160 & GX200 engines & Clone GX160 & GX200 engines.
HeadTearDownGuide
SKU EVCSKN
Rocker Tappet Valve Cover suit GX200/160 Clone including CPR engines with 4-Bolt cover
GX200 Valve Rocker Tappet Cover Spacer Aluminium with Vacuum Port
Rocker Tappet Valve Cover suit GX200/160 Clone including CPR engines with 4-Bolt cover GX200 Valve Rocker Tappet Cover Spacer Aluminium with Vacuum Port
$34.95
$99.95
Rocker Tappet Valve Cover Gasket Stock Clone Suit Honda Clone GX200 ENCL65
$8.95
