Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Vacuum NO BARB INSTALLED Manifold Sandwich
Vacuum sandwich (Insulator Bakelite type) to suit vacuum pulse external fuel pumps like the CPR External Fuel Pump.
This component fits between the carburettor and intake manifold on the Honda GX160/200 and clone.  The most reliable and easiest way to gain a good vacuum tap for external fuel pumps using vacuum pulse.
Dia of holes are 6.8mm (for a 6mm threaded stud) and they are 43mm centre to centre.
Bore/Venturi dia is 19.5mm
Same type as upgraded LIFAN 6.5HP honda clone engines (using our Upgrade Pack - ENUCL65).
SKU EVPC0NB
