Home :: Hop Up Kits :: Upgrade Throttle Linkage Kit for 4-Stroke Engine CPR OHV 9hp 13hp GX270 GX390 Complete
*We recommend the use of our BILLET FLYWHEEL when upgrading your engine for safety and club track rule adherance.
**DISABLE YOUR GOVERNOR WITHOUT OPENING YOUR ENGINE WITH THIS KIT.
**note: this kit will not remove the weights inside your engine which control the governor.  If you do not open your engine and remove these there is a risk they will dislodge and find their way into your engine, causing severe engine damage.  We strongly recommend removing the weights from your engine when using this kit to avoid engine damage.  You can learn how to remove the weights in our guide here: https://cutpriceracing.com.au/store/Page40/
Throttle Linkage upgrade pack to suit our CPR 9HP honda clone engines as well as GX270 style and 13hp GX390 engines.
This kit adds a remote linkage to your engine, removing the governor in the process.  Can be used to replace the static lever on 4-stroke engines, or as a simple way to remove the governor, or as part of a complete race upgrade.
Bolt-on complete fitment for our CPR 9HP engines or GX270/GX390 & clone engines.
Components included:
- Throttle cable
- Throttle Cable Terminator
- Assembly instructions (electronic version on our Forum - you can view the assembly guide here: https://cutpriceracing.com.au/store/ENUCL39-GX390-Hop-Up-Kit-Installation-Guide/
Get more power, easily!
*Note - fitting top plate will require removal/relocation of standard fuel tank.  Our external fuel pump will bolt directly to the pre-drilled holes in the top plate in this kit.
SKU ENTLUK3
