Home :: Hop Up Kits :: Upgrade Throttle Linkage Kit for 4-Stroke Engine CPR OHV 6.5hp 192cc Complete
REMOVE YOUR GOVERNOR WITHOUT OPENING YOUR ENGINE WITH THIS KIT.
Throttle Linkage upgrade pack to suit our CPR 6.5HP honda clone engines.
This kit adds a remote linkage to your 6.5hp engine, removing the governor in the process.  Can be used to replace the static lever on 4-stroke engines, or as a simple way to remove the governor, or as part of a complete race upgrade.
Bolt-on complete fitment for our CPR 6.5HP engines.
Components included:
- Throttle cable
- Throttle Cable Terminator
- Assembly instructions - you can view the assembly guide here: https://cutpriceracing.com.au/store/Page43/
Get more power, easily!
*Note - fitting top plate will require removal/relocation of standard fuel tank.  Our external fuel pump will bolt directly to the pre-drilled holes in the top plate in this kit.  When connecting throttle cable to pedal, check throw and adjust so that the maximum throttle cable travel does not try to over-rotate the butterfly on the carburettor or you will risk damaging the plastic clip on top of the carburettor throttle shaft.
Brand New Throttle Linkage Upgrade Kit to suit 4-Stroke Engine LIFAN 6.5hp OHV 192cc (Honda Clone)
SKU ENTLUK
Regular price: $256.27
Price with FREE DELIVERY: $99.00
