Home :: Airboxes, Filters & Parts :: Filters :: Air Filter suits Upgrade Kit for 4-Stroke Engine
Air Filter
Suits 4 stroke engines with approx 62mm OD connection (including TORINI Clubmaxx 4SS Engine, CPR 4-stroke engines, 9hp, 13hp, 16hp honda clone enignes using a compatible venturi adaptor)
Suits upgraded CPR 6.5HP honda clone engines (using our Upgrade Pack - ENUCL65)
Requires Venturi Adaptor to fit standard honda clones - see bottom of page.
Filter neck ID approx 62mm.
Length of neck: 54mm (top), 30mm (bottom) - angled.
Element dimensions:
Approximately 102mm long
Approximately 100mm diameter at the large end
Approximately 85mm diameter at the small end
TappetCoverBreathergGuide
SKU FLC01
