Home :: Hop Up Kits :: Upgrade Kit 10hp Hop Up for 4-Stroke Engine GX200 / LIFAN OHV 6.5hp 192cc Complete
This kit replaces Air Intake system, upgrades the fuel system to an external tank and high flow fuel pump, upgrades exhaust system and includes all springs and connectors necessary for a complete change-over.   Also includes polished aluminium professionally welded deflector and mount plates.  Your engine will look fantastic after this upgrade!
Components included:
- External Fuel Pump
- Billet Aluminium Tig Welded & Polished Clutch/Chain Cover
- Sports Muffler Header pipe and tip
- Exhaust Gasket
- Pod-Style air filter
- 88 Fuel Jet for ideal fuel mixture due to lean-out from better breathing
- Billet Aluminium High-Flow Venturi
- Vacuum Line
- Fuel Line
- Race Fuel Filter
- Throttle cable
- Throttle Cable Terminator
- Assembly instructions online (see the guide link below)
Get more power, easily!
ST1UpgradeGuide
SKU ENUCL65
Regular price: $1526.50
Price with FREE DELIVERY: $279.00
