Home :: Hop Up Kits :: Upgrade Kit 10hp+ Hop Up for 4-Stroke Engine GX200 / LIFAN OHV 6.5hp 192cc Complete (With Race Muffler, Valve Springs, Gaskets, Billet Rod)
***THIS MODEL DOES NOT INCLUDE THE SIDE PLATE / CHAIN GUARD***
This kit replaces Air Intake system, upgrades the fuel system to an external tank and high flow fuel pump, upgrades exhaust system to racing specification and includes all springs and connectors necessary for a complete change-over.   Also includes replacement billet connecting rod to ensure your engine does not seize at high rpm, as well as head gasket and side cover gasket for convenience.  Includes 18lb valve springs to elimate valve float at higher rpm.  Your engine will look and perform fantastic after this upgrade!
Components included:
- External Fuel Pump
- Racing RLV Muffler Header pipe and tip
- Exhaust Gasket
- Pod-Style air filter
- 98 Fuel Jet for ideal fuel mixture due to lean-out from better breathing
- Billet Aluminium High-Flow Venturi
- Vacuum Line
- Fuel Line
- Race Fuel Filter
- Throttle cable
- Throttle Cable Terminator
- Billet Connecting Rod and bearing (stock lenght, suits stock  style pistons including flat top and standard type cranks)
- Side Cover Gasket (to suit standard 4-bolt rocker cover style GX200 and clone)
- High compression head gasket
- 18lb spring parr
- Valve lash cap and converter retainer to provide 2x lash caps which assists in stopping the retainer sliding out at high rpm.
- Assembly instructions for throttle mount kit and standard upgrade kit parts online (see the guide link below)  - connecting rod and valve spring installs can be found on youtube eaisily.
Get more power, easily!
ST1UpgradeGuide
SKU ENUSM2
Regular price: $1837.27
Price with FREE DELIVERY: $669.00
