Home :: Hop Up Kits :: Upgrade Kit 10hp Hop Up for 4-Stroke Engine GX200 / LIFAN OHV 6.5hp 192cc Complete (No Chain Guard / Sideplate) (CLONE)
***THIS MODEL DOES NOT INCLUDE THE SIDE PLATE / CHAIN GUARD***
This kit replaces Air Intake system, upgrades the fuel system to an external tank and high flow fuel pump, upgrades exhaust system and includes all springs and connectors necessary for a complete change-over.   Also includes polished aluminium professionally welded deflector and mount plates.  Your engine will look fantastic after this upgrade!
Components included:
- External Fuel Pump
- Sports Muffler Header pipe and tip
- Exhaust Gasket
- Pod-Style air filter
- 88 Fuel Jet for ideal fuel mixture due to lean-out from better breathing
- Billet Aluminium High-Flow Venturi
- Vacuum Line
- Fuel Line
- Race Fuel Filter
- Throttle cable
- Throttle Cable Terminator
- Assembly instructions online (see the guide link below)
Get more power, easily!
ST1UpgradeGuide
SKU ENUCL65_NSP1
Regular price: $1386.59
