Home :: Clutches :: Torque Converters :: Torque Converter Clutch for Engines 9hp and Larger 25.4mm (1") bore
NEW MODEL! Designed for high reliability with engines 9hp and bigger (up to 20hp)
Want to learn how to install a torque converter and find dimensions of our unit?  Have a look at our install guide here.  (*NOTE: Install guide is for the smaller 'back-plated' version)
Suits Standard 25.4mm Drive Shaft (1") (straight shaft) and ~6mm keyway as used on most 9-20hp engines.
Includes DRIVER, DRIVEN and BELT.
TorqueConverterGuide
SKU TCCX1
Regular price: $944.50
