Home :: Clutches :: Torque Converters :: Torque Converter Clutch Complete Kit for Engines 9hp and Larger 25.4mm (1") bore with Jackshaft, Chain, Sprockets, Bearings, Belt (PRE-SELL)
*** THIS ITEM IS NOT IN STOCK BUT IS DUE 11/5/2018 - IF PURCHASED, ITEM WILL NOT BE SHIPPED PRIOR TO THIS DATE ***
NEW MODEL! Designed for high reliability with engines 9hp and bigger (up to 20hp)
Want to learn how to install a torque converter and find dimensions of our unit?  Have a look at our install guide here.  (*NOTE: Install guide is for the smaller 'back-plated' version)
Looking for the spacing between the pulleys or examples of installation?  CLICK HERE to view our guide
This converter is ideal for higher power engines and projects with large wheels or heavy vehicles.
It comes complete with everything required to set it up and make it operate except for nuts and bolts.
FREE 420P Chain and 420P sprocket (only one size available - 44T)
420 Pitch Torque Converter suit 4-stroke.
Suits Standard 25.4mm Drive Shaft (1") (straight shaft) and ~6mm keyway.
Includes 420P 10T drive sprocket.
Includes heavy duty belt
Includes 5/8" Jackshaft and key
Includes bearings and pillow blocks for easy mounting
TorqueConverterGuide
SKU TCCX1C_PS
