Home :: Clutches :: Torque Converters :: Torque Converter Clutch 35 Pitch 12Tooth & 420P 10Tooth 25.4mm (1") bore + FREE #35 Chain & #35 Sprocket
NEW MODEL!
Fits engines smaller than GX240.  Can be modified to fit larger engines, but this version is not designed for motors 9hp and larger - we recommend our TCCX versions for larger horsepower engines.
Want to learn how to install a torque converter and find dimensions of our unit?  Have a look at our install guide here.
Now with FREE #35 Chain and #35 sprocket of your choice!
Supplied with #35 12T.
Don't get stuck without gearing options running #40 or 420P sprockets, our #35 torque converter instantly provides you with access to our full #35 split sprocket range for the best gearing options available!
35 Pitch Torque Converter suit 4-stroke.
Suits Standard 25.4mm Drive Shaft (1") (straight shaft) and ~6mm keyway.
Includes #35 12T drive sprocket so you have the best range of gearing available.
Complete unit with everything required to fit - includes belt, drives, mounting plate, sprocket and cover.
All you need is a rear sprocket and a chain to get mobile!
TorqueConverterGuide
SKU TCC121C
Base product price: $329.00
