Home :: Clutches :: Torque Converters :: Torque Converter Clutch 420P 10Tooth 25.4mm (1") bore + FREE 420P Chain & Sprocket
NEW MODEL!
Fits engines smaller than GX240. Can be modified to fit larger engines, but this version is not designed for motors 9hp and larger - we recommend our TCCX versions for larger horsepower engines.
Supplied with 420P 10T.  Great for those of you with 'drift' karts which are difficult to convert to #35.
Want to learn how to install a torque converter and find dimensions of our unit?  Have a look at our install guide here.
Now with FREE 420P Chain and 420P sprocket (only one size available - 44T)
420 Pitch Torque Converter suit 4-stroke.
Suits Standard 25.4mm Drive Shaft (1") (straight shaft) and ~6mm keyway.
Includes 420P 10T drive sprocket.
Complete unit with everything required to fit - includes belt, drives, mounting plate, sprocket and cover.
Rear 420P 44T sprocket and a chain included!  Sprocket fits readily available 6-bolt pcd go kart hub/carrier.
TorqueConverterGuide
SKU TCC12142
Regular price: $976.27
