Home :: Clutches :: Torque Converters :: Torque Converter Clutch 35 Pitch 12Tooth & 420P 10Tooth 19.05mm (3/4") bore + FREE #35 Chain & #35 Sprocket
NEW MODEL!
Want to learn how to install a torque converter and find dimensions of our unit?  Have a look at our install guide here.
Now with FREE #35 Chain and #35 sprocket of your choice!
Supplied with #35 12T and 420P 10T so that you can opt for either pitch.  Great for those of you with 'drift' karts which are difficult to convert to #35.
Don't get stuck without gearing options running #40 or 420P sprockets, our #35 torque converter instantly provides you with access to our full #35 split sprocket range for the best gearing options available!
35 Pitch Torque Converter suit 4-stroke.
Suits Standard 19.05mm Drive Shaft (3/4") (straight shaft) and ~5mm keyway as used on most  6.5hp engines.
Includes #35 12T drive sprocket so you have the best range of gearing available.  **Now shipped with 420P 10T sprocket as well.
Complete unit with everything required to fit - includes belt, drives, mounting plate, sprocket and cover.
All you need is a rear sprocket and a chain to get mobile!
TorqueConverterGuide
SKU TCC1234C
Base product price: $329.00
