Home :: Clutches :: Torque Converters :: Torque Converter Clutch 35 Pitch 12Tooth & 420P 10Tooth 19.05mm (3/4inch) bore
*PLEASE NOTE: THIS ITEM IS NOT FOR SALE INDIVIDUALLY - IT MUST BE PURCHASED IN CONFIGURATION.  IF PURCHASED INVIDUALLY IT WILL BE SHIPPED WITH A 420P SPROCKET AND 420P CHAIN*
NEW MODEL!
Fits engines smaller than GX240. Can be modified to fit larger engines, but this version is not designed for motors 9hp and larger - we recommend our TCCX versions for larger horsepower engines.
Want to learn how to install a torque converter and get dimensions of our unit?  Have a look at our install guide here.
Don't get stuck without gearing options running #40 or 420P sprockets, our #35 torque converter instantly provides you with access to our full #35 split sprocket range for the best gearing options available!
35 Pitch Torque Converter suit 4-stroke.
Suits Standard 19.05mm Drive Shaft (3/4") (straight shaft) and ~5mm keyway as used on most  6.5hp engines.
Includes #35 12T drive sprocket so you have the best range of gearing available.  **Now shipped with 420P 10T sprocket as well.
Complete unit with everything required to fit - includes belt, drives, mounting plate, sprocket and cover.
TorqueConverterGuide
SKU TCC1234
