Home :: Clutches :: Torque Converters :: Torque Converter 3/4inch 19.05mm Driver (Standard Repkacement) suit TCC1234
Stock Replacement Part suits TCC1234 3/4" 19.05mm CPR Torque Converters.
Want to learn how to install a torque converter and get dimensions of our unit?  Have a look at our install guide here.
Suits Standard 19.05mm Drive Shaft (3/4") (straight shaft)
This is the Driver only - designed to upgrade our TCC121 style torque converters with 1" shaft.
TorqueConverterGuide
SKU TCDC34
