Home :: Clutches :: Torque Converters :: Torque Converter 1inch Driver (Standard Repkacement) suit TCC121
Stock Replacement Part suits TCC121 1" CPR Torque Converters.
Want to learn how to install a torque converter and get dimensions of our unit?  Have a look at our install guide here.
Suits Standard 25.4mm Drive Shaft (1") (straight shaft)
This is the Driver only - designed to upgrade our TCC121 style torque converters with 1" shaft.
TorqueConverterGuide
SKU TCDS25
