Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Torini Clubmaxx Carburettor (Homologated Part) - fit to GX200 using GX390 Carb Adaptor - SHOP SOILED (plastic throttle retainer tip damaged)
SHOP SOILED - This item has sustained damage in transit, it has been fitted, filled with fuel, drained and then removed from the engine due to the broken plastic throttle retainer clip being broken - see pictures.
Easy fix for someone looking for a cost effective fix for their Torini Clubmaxx, or to upgrade a GX200 to a bigger carb.
**DAMAGED PART IS INCLUDED and fits back together perfectly as it was a clean break, COULD ALSO BE EASILY GLUED BACK IN PLACE**
Stock stud spacing is 52mm centre to centre, 6mm studs
Butterfly/Bore size 19mm
This can be fitted to GX200 engines using the GX390 adaptor found by clicking here
Complete kit with studs and gaskets.
SKU CHTCK1
Price with FREE DELIVERY: $54.90
