Home :: Engines, Carbs & Parts :: Engines :: Top & Side Plate (Fuel Pump mount & Clutch / Drive Sprocket cover guard) PACK to suit 4-Stroke Engine LIFAN Honda Clone
Top & Side Plate (Fuel Pump mount & Clutch / Drive Sprocket cover) PACK to suit 4-Stroke Engine LIFAN Honda Clone
These plates will ensure you comply with rules and regulations for covering the engine side of the drivetrain and mounting external fuel pumps on your honda clone engine.  The side plate is designed to cover clutch and drive sprocket, all the way to the rear sprocket if the engine is mounted close to the rear axle.  The top plate is designed to safely mount an external fuel pump (drilled to suit our CPR standard vacuum pulse fuel pump)
Bolt-on complete simple fitment for our LIFAN 6.5HP engines - also bolts onto most other clones.
Brand New Top & Side Plate (Fuel Pump mount & Clutch / Drive Sprocket cover) PACK to suit 4-Stroke Engine LIFAN Honda Clone
SKU ENPB65
Regular price: $134.55
Price with FREE DELIVERY: $109.00
