Home :: Clutches :: Thrust Washer & Bearing Set suits Bully 19mm (3/4") bore
Thrust Washer & Bearing Set to suit 3/4" 19.05mm Bully Clutches
*Note thrust washers are slightly thicker than stock bully - this does not cause any issues but may require adjustment to shimming on your output shaft to ensure correct play (zero mm)
GTClutchServiceGuide
SKU CLCHP678B
Price with FREE DELIVERY: $19.95
