Home :: Tachos, Laptimers & Gauges :: Tachos & Speedometers :: Tacho GT CPR 2 or 4-Stroke with Max RPM Recall - Easy To Read Large Display, Backlight, Replaceable Battery, RPM Alert
*NOTE FOR BEST RESULTS, WIND LEAD AROUND HIGH TENSION PLUG LEAD UP NEAR THE SPARK PLUG BUT NOT OVER THE THICK RUBBER OF THE PLUG CAP - MAKE SURE YOU CONNECT TO THE THINNER 'LEAD' SECTION CLOSEST TO THE CAP OF THE PLUG.
Feature-rich TACHO at a budget-racer price.
NEW Front-Mounted Buttons RESETTABLE MAX RPM FUNCTION!  PLUS SERVICE REMINDERS!
This model suits both 2 & 4 stroke karts.  Uses a simple and easy switch to adjust.  (For 4-stroke single cylinder such as GX200 use set to 1P2r)
Simple induction system - run the wire to your spark plug lead and place alongside - we recommend parallel to the spark plug wire just before the end-cap.  It's best to use a zip-tie/cable tie, but you can also use some tape.  While you can wrap the sensor wire around the spark plug lead, this will not be as accurate due to interference from coiling the sensor wire.
Adjust sensitivity and update smoothness easily.
Reset Hour-meter easily.
COMPLETE  EVERYTHING you need to bolt-on and go - including ALL the screws. This is a dream price!
1x up to 20,000rpm TACHO with MAX-RPM Recall and Sensitivity/Display adjustment features
1x HOURMETER (hourmeter and tacho is one unit)
1x 1.4m sensor lead
1x Battery
OVERSPEED RPM ALERT
LARGE 5 digit LCD screen
BACKLIGHT
Tacho with 1rpm resolution
Up to 20,000rpm readout
Hourmeter (trip/engine resettable - total hours not resettable)
SERVICE/REBUILD reminder at 0-200hrs (adjustable)
Auto switching Tacho/Hourmeter (Switches to hourmeter readout when engine switched off.  Switches to tacho readout when engine on)
waterproof level IP65
Designed for go karts.
DOWNLOAD THE MANUAL
SKU TCHCGT
