Home :: Steering Components :: Stub Axles & Spindles :: Stub Axle Spindle Suit Arrow CRG Silver Pair w/Gold Spacers
That means you get EVERYTHING you need to make these work!  You won't be searching for spacers, or nuts or kingpins, or bearings, just bolt up and go!
These are quality chrome plated stub axles / sprindles with 17mm Stub Axles for Race Karts.
Why is the price so low if they are such good quality?  Well you're not buying a brand name so we can keep the price lower!  When brands are distributed, profits are shared between 2 or 3 different sellers - there's the master distributor, the wholesaler, and the retailer who all have markups on that product.  By the time you buy it, you're paying loads more.  We buy direct from the factory and then ship it directly to you, so you're not paying all these people along the way.
Colour: Silver
INCLUDES KING PIN BOLTS
INCLUDES SPACER WASHERS (One set of 8 - 4x10mm & 4x5mm spacer washers - Colour as per title & title picture - NOTE:
 You may require additional spacers depending on the distance between the outer faces of your rims or hubs)
INCLUDES WHEEL NUTS
INCLUDES BEARINGS
KING PIN Diameter: 8mm
Dimension A: 100mm
Dimension B: 18mm
Dimension A+B: 118mm
Dimension C: 22mm
Dimension E: 52mm
Dimension F: 2mm
Dimension C+D+E+F: 172mm
Dimension G: (thickness of spindle) = 41mm
StubAxleGuide
SKU STAC1G
Regular price: $940.73
