Home :: Steering Components :: Stub Axles & Spindles :: Stub Axle Spindle Suit Arrow CRG Silver Pair
Colour: Silver
INCLUDES KING PIN BOLTS
INCLUDES WHEEL NUTS
INCLUDES BEARINGS
KING PIN Diameter: 8mm
Dimension A: 100mm
Dimension B: 18mm
Dimension A+B: 118mm
Dimension C: 22mm
Dimension D: 98mm
Dimension E: 52mm
Dimension F: 2mm
Dimension C+D+E+F: 172mm
Dimension G: (thickness of spindle) = 41mm
StubAxleGuide
SKU STAC1
