Home :: Steering Components :: Stub Axles & Spindles :: Stub Axle RACE MOWER COMPLETE FRONT END KIT Spindles Front Wheel Hubs w/3x78mm Hub Adaptors Adapters w/Red Spacers and Brackets
NEW MODEL - COMPLETE WITH CAMBER ADJUSTMENT SYSTEM!
CPR Race Mower kits include everything you'll need to quickly, easily, and correctly install the front end steering assembly.  Includes weld-on brackets and hub adaptors to suit most 3-stud mower front wheels.
CPR Race Axle Assemblies have been crafted to suit high horsepower, high G-Force racing - off-road and on-road.  Our Racing Mower kits are designed to provide the ultimate strength with a premium engineered, strong stub shaft, specifically suited to the rigors of high horsepower, high weight racing mower competition.
Not only are CPR Race Front End Assemblies high quality, but they also represent outstanding value for money.  When you replace or add a CPR kit, you'll have access to replacement parts at unbeatable value into the future.
KIT INCLUDES:
BRAND NEW Stub Axle pair with BRAND NEW bearings, BRAND NEW spacer washers, BRAND NEW wheel nuts, FRONT WHEEL HUBS, and FRONT WHEEL HUB ADAPTORS!
If you're looking for a quality correctly manufactured component for a race mower which will be compatible with 3x78mm Mower front wheels then don't get caught with a 15mm or even worse 10mm stub setup that you can't buy parts for.  Make sure you get yourself a kit lke this with 17mm stubs so you can buy wheels and bearings anywhere!
The RACING MOWER SERIES range of CPR products includes Brackets which weld to your frame to accept these spindles.  Your complete kit comes with two spindle brackets which can be welded to your mower frame to update/upgrade to CPR spindles.
Colour: Silver
INCLUDES
- KING PIN BOLTS
- SPACER WASHERS (One set of 10 - 6x10mm & 4x5mm spacer washers - Colour as per title & title picture) - enough to properly fit the included wheel hubs.
- WHEEL NUTS
- BEARINGS
- CAMBER ADJUSTMENT BUSHES WITH HEX ADJUSTMENT x4pcs (2x pairs)
- LOCKING BOLTS x4
KING PIN Diameter: 8mm
Dimension A: 100mm
Dimension B: 18mm
Dimension A+B: 118mm
Dimension C: 22mm
Dimension D: 98mm
Dimension E: 52mm
Dimension F: 2mm
Dimension C+D+E+F: 172mm
BRAND NEW BILLET FRONT WHEEL HUB PAIR
BILLET ALLOY PERFORMANCE
FITS COMMON RACE KARTS
COLOUR CHOICES
Front Wheel Hub/Carrier PAIR.
Two pieces in this set.
Colour as pictured.
70mm Length (Medium).
Suit 17mm Stub Axle.
Holes are set 50mm apart from each other and 29mm from the centre (Suit Standard Rear Wheels). OR 78mm x3 to suit Mower front wheels when used with included hub adaptors.
BRAND NEW RACING MOWER HUB ADAPTORS
Rear Wheel Hub Adaptor PAIR (Does NOT include rear wheel hubs - pictured for reference only)
Holes are set 50mm apart from each other and 29mm from the centre (Suit Standard Rear Wheels) and plate holes are 78mm from each other (78mm x3 PCD)
StubAxleGuide
SKU STAMR
Regular price: $1246.55
